User's Guide | |
For the administratorThe Address Book and one-touch buttons can be exported/imported. This can be used for backup data if a failure occurs or to simplify the procedure for registering destinations between supported machines. For more information, see Backing Up/Restoring Data.
The Address Book can be personalized for each logged-in user (List of Items That Can Be Personalized). Furthermore, the Synchronize Custom Settings facility can be used to enable the Address Book to be shared by a number of Canon multifunction printers (Synchronizing Settings for Multiple Canon Multifunction Printers).
You can set a password to avoid unauthorized editing or deletion in the Address Book. Setting a PIN for Address Book
If there are destinations that you do not want to display in the Address Book or if you want to limit user access to destinations, enter an access number when registering a destination. To use the access number, it is necessary to activate the setting in advance in Restricting Access to Destinations Registered in the Address Book.
Configure User Group Address Lists from the Remote UI. (Registering Destinations via the Remote UI)
