Paper Jams in the Staple Finisher
1713-06Y
1
Check whether paper is jammed in the finisher.
Open the front cover of the finisher.
Lift up the output tray paper supporter of the Tray B.
Turn the green knob to feed the jammed paper to the Tray B side.
If paper comes out of the outlet of the Tray B, gently pull the paper out in the direction of the arrow.
2
Check whether paper is jammed in the delivery unit.
Open the escape delivery guide (  ).
If paper is jammed, gently pull it out in the direction of the arrow.
Lift up the first flapper (  ).
Return the first flapper (  ) to its original position.
Return the escape delivery guide (  ) to its original position.
3
Close the front cover of the finisher.
4
Open the cover of the buffer pass unit.
5
Check whether paper is jammed.
6
Close the cover of the buffer pass unit.
Continue following the instructions on the screen to proceed with the interrupted operation or continue clearing paper jams.
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
