The control panel consists the numeric keys, , indicators, touch panel display, etc. You can perform all the operations and specify settings from the control panel. Control Panel
Feeder
Automatically feeds originals into the machine for scanning. When two or more sheets are loaded in the feeder, originals can be scanned continuously. Feeder
This code indicates the type of genuine toner that can be used with the machine. Use toner with a code that includes the same letters as the code on the front cover of the machine.
For more information about the configuration of optional equipment installed on the machine, see Options.
Connecting a USB Memory Device
You can connect a USB memory device to the USB ports located on the right side of the machine, and directly print data from the USB memory device. Originals scanned using the machine can also be saved directly to the USB memory device. Working with Data in Memory Media
Disconnecting the USB memory device
1
Press .
2
Select the USB memory device that you want to disconnect and press <Remove>.
3
Disconnect the USB memory device from the USB port and press <OK>.
Make sure to follow the proper procedure when removing the memory media. Failure to do so may cause the memory media or machine to malfunction.
The machine supports FAT32/exFAT format memory media.
Make sure that the memory media is oriented properly when connecting it to the machine. If it is not connected properly, it may cause the memory media or machine to malfunction.
Be sure to check before using memory media
To use the memory media, it is necessary that <Memory Media> in <Store Location Display Settings> is set to <On>.
When the memory media is not recognized even if it is connected properly, the machine may be set to use the MEAP driver for USB external storage device. Set <Use MEAP Driver for USB Storage Device> to <Off>. <Use MEAP Driver for USB Storage Device>
Unsupported devices and usages
Memory media with security functions
Memory media that does not meet the USB specification
