Inner Shift Sorter-A
1713-0SX
Paper Sizes
No finishing set, Collte, and Group mode:
Max: 12 5/8" x 18" (320 x 457.2 mm)
Min: 3 7/8" x 5 1/2" (98 x 139.7 mm)
Collate + Offset and Group + Offset mode:
Max: 11 3/4" x 17" (297 x 431.8 mm)
Min: 5 1/2" x 5 1/2" (139.7 x 139.7 mm)
Paper Weight
14 lb bond to 110 lb cover (52 to 300 g/m²)
14 lb bond to 140 lb index (52 to 300 g/m²)
Paper Type
Paper available for the Main Unit
Thin, Plain, Heavy 1 to 5, Recycled, Coated 1 to 4, Color, Pre-Punched, and Bond
Capacity Per Tray*1
LTR, EXEC, A4, B5, and 16K: 250 sheets (20 lb bond (80 g/m2)) or 1 1/2" (37.2 mm) in height
11" x 17", LGL, LTRR, STMT, STMTR, 320 x 450 mm (SRA3), 305 x 457 mm, A3, B4, A4R, B5R, A5, A5R, 8K, and 16KR: 125 sheets (20 lb bond (80 g/m2)) or 3/4 (18.6 mm) in height
Other sizes: 10 sheets
With different paper sizes: 125 sheets (20 lb bond (80 g/m2)) or 3/4 (18.6 mm) in height*1
A3, B4, A4R, A5, A5R, B5R, 11" x 17", LGL, LTRR, STMT, STMTR, 8K, and 16KR: 125 sheets (80 g/m2) or 18.6 mm in height
Dimensions (W x D x H)
17 3/4" x 20 5/8" x 4 1/2" (452 x 523 x 114 mm)
Weight
Approximately 6.6 lb (3 kg)
Installation Space Including the Main Unit
(W x D)
42 1/8" x 44 1/4" (1,071 x 1,123 mm) (when the auxiliary tray is extended)
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
