Viewing User's Guide
1713-098
This section describes the marks, buttons, screens, and other items used in the User's Guide. The warnings and cautions are also given in the "Important Safety Instructions" in the "FAQ Guide" included with the machine. See also these instructions.
Marks
Cautions regarding safety, restrictions and cautions regarding the handling of the machine, useful tips, and other information are indicated using the marks below.
Indicates a caution concerning operations that may lead to injury to persons if not performed correctly. To use the machine safely, always pay attention to these cautions.
Indicates an operation that must not be performed. Read these items carefully, and make sure not to perform the described operations.
Indicates operational requirements and restrictions. Be sure to read these items carefully to operate the machine correctly, and avoid damage to the machine or property.
Indicates a clarification of an operation, or contains additional explanations for a procedure.
TIPS
Indicates useful functions or tips for using the machine.
Keys and buttons
Keys on the control panel, buttons displayed on the touch panel display and buttons on the computer screen are indicated as follows.
Type
Example
Buttons on the touch panel display*
<Function Settings>
<Cancel>
Buttons and other text interfaces displayed on the computer display
[Preferences]
[OK]
* Operation to touch a button on the touch panel display is indicated as "Press" in the User's Guide.
Screen
Screens used in the User's Guide are from "imageRUNNER ADVANCE C3530i" with the following options installed unless otherwise specifically noted.
Booklet Finisher-AA
Cassette Feeding Unit-AP
Super G3 FAX Board
Because functions that can be used differ depending on the combination of options, a screen may be different from actual screens displayed in that a button or an item may not be displayed.
Depending on the OS you are using, a portion of the indicated screen content may differ from your computer.
The screen content for drivers and software may differ due to version upgrades.
Illustrations
Illustrations used in the User's Guide are from "imageRUNNER ADVANCE C3530i" with the following options installed unless otherwise specifically noted.
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
