Feeder
1713-01K
This section describes the name and use of each part of the feeder.
Original set indicator
Lights up when originals are placed in the original supply tray.
Feeder cover
Open this cover when removing paper jammed in the feeder. Paper Jams in the Feeder
Slide guides
Adjust these guides according to the width of an original.
Original supply tray
Originals placed here are automatically fed into the feeder. When two or more sheets are loaded, originals can be scanned continuously. Placing Originals
Original supply tray extension
Pull out this tray when loading a large-sized original.
Document feed scanning area
Originals placed in the feeder are scanned in this area.
Document feed scanning area cover
Open this cover when replacing a stamp cartridge or cleaning the document feed scanning area. Maintenance
Platen glass
When scanning books, thick originals, thin originals, and other originals that cannot be scanned using the feeder, place them on the platen glass. Placing Originals
Original output tray extension
Pull out this tray when scanning large-sized originals to prevent them from dropping over the edge of the feeder. The tray can be extended to two different lengths depending on the size of original.
Original stopper
Holds down originals to support outputting originals neatly.
Scanned originals are output here.
Original output indicator
If you place originals in the feeder while originals for another job remain in the original output tray, the indicator blinks to notify the user that originals remain.
Do not place any objects in the original output area. Doing so may cause damage to the originals.
Regularly clean the feeder and platen glass in order to obtain proper print results. Regular Cleaning
TIPS
If the Stamp Unit is installed in the feeder, the Finished Stamp will be available.
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
