Checking the Connection to the Recipient Before Sending (Direct Send)
1713-0CR
To successfully send faxes to the destination you intend, you can check beforehand that the recipient is connected and ready to start communication. As the machine bypasses memory when scanning originals, you can send faxes even if there is no memory available.
1
Place the original. Placing Originals
To send multiple pages, place the originals in the feeder. When the original is placed on the platen glass, only one page can be sent.
2
Press <Fax> on the Main Menu. <Main Menu> Screen
3
Specify the destination on the Fax Basic Features screen. Fax Basic Features Screen
4
Specify the scan settings as necessary. Basic Operations for Sending Faxes
5
Press <Options>  <Direct Send>.
6
Press .
The machine dials the recipient's number. When the machine connects the call, originals are scanned and sending starts.
The machine does not start sending when the recipient's line is busy.
Direct Send is not available in the following cases
Any of the following scan settings are specified: <2-Sided Original>/<Different Size Originals>/<Erase Frame>/<Job Build>/<Delayed Send>/<Finished Stamp>
Multiple destinations are specified.
<Limit Functions> is set to <Off> for any function when the machine is in the Department ID mode. Configuring the Department ID Management Settings
To specify the scanning size of originals
The scanning size of originals placed in the feeder is automatically set. To specify the size yourself, use the platen glass.
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
