User's Guide | |
Paper Sizes
Paper Drawer 1
Paper Drawer 2, 3, or 4
Multi-Purpose Tray
11" x 17"
LGL
LTRR
LTR
STMTR
STMT
EXEC
320 x 450 mm (SRA3)
305 x 457 mm
A3
B4
A4R
A4
B5R
B5
A5R
A5
8K
16KR
16K
Custom Size
Yougatanaga 3
Nagagata 3
Kakugata 2
No.10 (COM10)
Monarch
DL
ISO-C5
Custom Size (Envelope)
Paper Type
Paper Drawer 1
Paper Drawer 2,
3, or 4 |
Multi-Purpose Tray
Thin 2
14 to 15 lb bond (52 to 59 g/m2)
Thin 1
16 lb bond (60 to 63 g/m2)
Plain 1
17 to 20 lb bond (64 to 75 g/m2)
Plain 2
21 to 24 lb bond (76 to 90 g/m2)
Plain 3
25 to 28 lb bond (91 to 105 g/m2)
Heavy 1
29 to 34 lb bond (106 to 128 g/m2)
Heavy 2
35 to 40 lb bond (129 to 150 g/m2)
Heavy 3
56 to 60 lb cover (151 to 163 g/m2)
Heavy 4
61 to 66 lb cover (164 to 180 g/m2)
Heavy 5
67 to 80 lb cover (181 to 220 g/m2)
Heavy 6
82 lb cover to 140 lb index (221 to 256 g/m2)
Heavy 7
100 to 110 lb cover (257 to 300 g/m2)
Recycled 1*1
Recycled 2*1
Recycled 3*1
1-Sided Coated 1
1-Sided Coated 2
35 lb bond to 60 lb cover (129 to 163 g/m2)
1-Sided Coated 3
61 to 80 lb cover (164 to 220 g/m2)
1-Sided Coated 4
82 to 95 lb cover (221 to 256 g/m2)
2-Sided Coated 1
2-Sided Coated 2
2-Sided Coated 3
2-Sided Coated 4
Color
17 to 21 lb bond (64 to 82 g/m2)
Tracing
17 to 26 lb bond (64 to 99 g/m2)
Pre-punched
Transparency*2
32 lb bond to 80 lb cover (121 to 220 g/m2)
Labels
31 lb bond to 68 lb cover (118 to 185 g/m2)
Bond*3
22 to 26 lb bond (83 to 99 g/m2)
Envelope
20 to 28 lb bond (75 to 105 g/m2)
Postcard
Paper size:
11" x 17", LGL, LTR, LTRR, STMTR, EXEC, 305 x 457 mm, A3,
B4, A4, A4R, B5, B5R, A5, A5R, 8K, 16K, 16KR, Custom Size*1 |
Paper weight:
14 lb bond to 80 lb cover (52 to 220 g/m2)
*1 1-Sided Coated, 2-Sided Coated, Tracing, Transparency, Labels, Free size paper, and Envelope are not available for 2-sided copying.
Do not use the following types of paperDoing so may cause a paper jam or other printing problems.
Wrinkled or creased paper
Curled or rolled paper
Torn paper
Damp paper
Very thin paper
Thin straw paper
Paper printed by a thermal transfer printer
The reverse side of paper which has been printed by a thermal transfer printer
Highly textured paper
Glossy paper
When using paperOnly use paper that has fully acclimatized to the environment in which this machine is installed. Using paper that has been stored under different temperature or humidity may cause paper jams or result in poor print quality.
Paper handling and storageWe recommend using the paper immediately after opening the package. Rewrap any remaining paper in its original package, and store it on a flat surface.
Keep the paper wrapped in its original package to protect the paper from moisture or dryness.
Do not store the paper in such a way that may cause it to curl or fold.
Do not store the paper vertically or stack too much paper.
Do not store the paper in direct sunlight, or in a place subject to high humidity, dryness, or drastic changes in temperature or humidity.
When printing on paper that has absorbed moistureSteam may emit from the paper output area, or water droplets may form around the paper output area. There is nothing unusual about any of these occurrences, which occur when the heat generated from fixing toner on the paper causes moisture in the paper to evaporate (most likely to occur at low room temperatures).
