Correcting Uneven Density
1713-05K
If the density is uneven when printing, perform <Correct Shading>. There are three methods for correcting the density; Correction with a Densitometer with a commercial densitometer, Visual Correction, and Scanner Correction.
Adjustments may not be performed effectively if there is not sufficient toner.
Measure a test page you have output with a commercial densitometer and enter the measured density values to correct the density of halftone areas.
1
Press   <Adjustment/Maintenance> <Adjust Image Quality> <Correct Shading> <Densitometer Correction>.
2
Press <Start Printing>.
A test page is printed.
3
Measure the test page with a densitometer.
Measure marks 1 to 7 printed on the test page, and make a note of the density values that are detected.
4
Press <Fine Adjust> for each color.
5
Enter the density values.
Enter the density values you measured and made a note of in step 3 in 1 to 7 for each color.
6
Press <OK>.
7
Press <Output Test Page> <Start Printing>.
A test page after correction is output.
8
If there is no problem with the test page, press <Store and Finish>.
If the density of the test page after correction is uneven, perform the procedure indicated in Visual Correction.
Visual Correction
Visually measure a test page you have output to perform correction using the density adjustment values you determine. Use this procedure when you do not have a densitometer or when correction is not effective.
1
Press   <Adjustment/Maintenance> <Adjust Image Quality> <Correct Shading> <Visual Correction>.
2
3
Visually check the test page to determine the density adjustment values.
The range of marks printed for each color may be -6 to +6 or -5 to +5, depending on the paper size used for the test page.
4
5
Enter the density values according to the results that you visually checked in step 3 from -6 to +6 (or -5 to +5) for each color.
Enter a plus value to increase the density, or a minus value to decrease the density.
6
Press <OK>.
7
8
Scanner Correction
You can perform density correction by scanning a test page that you have output. This saves the labor of performing density measurements and entering density values.
1
Press   <Adjustment/Maintenance>  <Adjust Image Quality>  <Correct Shading>  <Scanner Correction>.
2
Select the paper source and press <OK>.
3
The test page refers to a sheet of paper with four color stripes printed, which you use in the following steps.
4
Place the test page on the platen glass.
Place the test page sheet in the machine in a manner that its side on which the four color stripes are printed faces down and the cyan stripe faces toward the back side of the machine.
5
Close the feeder and press <Start Scanning>.
The test page is scanned and density correction is performed.
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
