<Accessibility>
This section describes settings for improving accessibility, such as the speed at which the same character is entered repeatedly when a key is held down, and reversing the contrast of the touch panel display.
<Key Repetition Settings>
  <Preferences> <Accessibility>
You can set the amount of time before characters start repeating when you hold down a key on the touch panel display, as well as the interval between repetitions.
<Reversed Display (Color)>
You can invert the screen colors of the touch panel display. If you find it hard to view the display even after adjusting the brightness, try specifying this setting.
<Enable Screen Magnification>
On the Main Menu screen and the Basic Features Screen of each function, you can zoom in or out by spreading two fingers apart (zoom in) or pinching two fingers together (zoom out).
1713-03U
