User's Guide | |
When copying documents that include confidential information, you can embed invisible text such as "TOP SECRET" or "CONFIDENTIAL" to warn unauthorized users not to copy them. When copying a document that has already been copied, the embedded text appears across the entire page, preventing unauthorized copies of copies. System Options
1
Press <Watermark>.
2
Select the type of watermark.
![]() To embed arbitrary text, select <Custom> and enter the text by pressing <Enter>.
![]() You can register frequently used text. Select <Custom> and enter the text by pressing <Register>.
To edit or delete registered text, press <Register>, select the text from the list, and press <Edit> or <Delete>.
1
Press <Date>.
2
Set the dates to embed.
![]() The dates set in the machine are displayed in <Specify date>. To embed other dates, enter using the numeric keys.
3
Select the format for dates.
Press <Date Format> to select the date format.
1
Press <Copy Set Numbering>.
2
Enter the starting reference number.
![]() Enter in the input field of <Starting Number> using the numeric keys.
1
Press <Serial Number>.
1
Press <ID/User Name>.
