You can select the optimal image quality for the copy depending on the type of original such as originals with only characters or magazines with photographs.
If you select <Printed Image>, you can copy printed photographs (photographs made with halftone dots) with optimal print quality.
If you select <Photo Printout>, you can copy photographs printed on photographic paper with optimal print quality.
6
Press <OK> <Close>.
If you select <Photo Printout> and copy, highlights may be blown out (areas with stronger brightness may become bright white). In this case, adjust the background density so that blow out does not occur. Press <Options> <Density> <Adjust> for <Background Density> <+>.
