User's Guide | |
Server/Client Machine
Client Machine
Client Machine
Up to 10 machines including the server machine can be synchronized.
Synchronized values may not be reflected, depending on the optional products and the machine configuration.
A server machine can either be used as a server machine that does not synchronize its own data, or as both a server and client machine (server/client machine).
If you do not start client functions on the server machine, data specified on the server machine will not be reflected in client machines.
Initial Check
Are the machines to synchronize correctly connected to the network?
Exporting the User Data
It is recommended that you export the user data for backup purposes. Importing/Exporting the Setting Data
Starting the Server Machine
Start synchronization on the server machine. Starting Setting Synchronization
Specifying the Detailed Synchronization Settings
Specify the detailed synchronization settings on the server machine. Specifying Detailed Synchronization Settings (Server Machine or Server/Client Machine)
Starting Synchronization
Specify the connection destination on the client machines and start synchronization. Starting Setting Synchronization
Checking Synchronization
Check the detailed synchronization settings, registered users, and connected machines on the server machine. Specifying Detailed Synchronization Settings (Server Machine or Server/Client Machine)
To change the scope of sharing, etc. after starting synchronization, shut down all the client machines, change the settings on the server machine, and start all the client machines again. Specifying Detailed Synchronization Settings (Server Machine or Server/Client Machine)
Synchronization starts after the client machines are restarted.
When a client machine starts and connects to the server machine, the user data registered in both the server machine and client machine is overwritten with the user data in the server machine, and the user data set in the client machine is deleted. To use the user data in a client machine to be connected to, delete the corresponding data from the server machine via <Delete User Data> in <Synchronize Custom Settings (Server)> before starting the client machine.
If different data exists for the same user in multiple client machines that are started in succession, the user data in the client machine that first connected to the server is used for synchronization.
If a problem occurs in the server machine or a client machine after starting synchronization, the data with [Device-Specific (Not Shared)] set for its scope of sharing in the machine with the problem returns to its default settings and is not restored.
A machine operating as a server machine will not completely enter sleep mode while one or more machines connected as a client machine are operating.
If a machine operating as the server machine is also connected as a client machine and is set to connect to localhost via a proxy server, that machine will not completely enter sleep mode.
To synchronize custom settings between machines, the machine authentication settings and group management settings must be the same. For information on specifying the same authentication settings, see the instructions for the login application. For group management settings, it is recommended that the settings in one machine are exported and imported into the other machines. When Department IDs are used for group management, set the same Department IDs for each machine.
To synchronize the information regarding the network places for keychains, the order that the network places are registered must be the same in all machines.
If a machine you are using is an older version, registered shortcuts and keychains may not be synchronized.
If synchronization of custom settings (client) and synchronization of custom settings (server) are started, <Action When Maximum Number of Users Exceeded> is set to <Delete Oldest User Settings> and cannot be changed.
Set the correct time in the SNTP settings (<SNTP Settings>) before enabling the server functions in the machine operating as the server machine.
If synchronization of custom settings (client) is started, the data subject to synchronization (including the Address Book) becomes unable to be imported or exported. For information on importing/exporting settings data, see Importing/Exporting the Setting Data. For information on the data subject to synchronization of custom settings, see List of Items That Can Be Personalized.
