Adjustment in <-> Direction is Recommended for Following Cases
Adjustment in <+> Direction is Recommended for Following Cases
Paper Weight
Light (thin paper)
Heavy (thick paper)
Poor Images
Although the density in the high density areas is normal, tiny white spots may appear in the low density areas.
White spots appear in high density areas.
Enough toner is not applied in high density areas, and tiny dense spots appear.
Dense spots may appear in low-density areas.
In high-density images, streaks of uneven density may appear along the feeding direction.
High-density parts may not be sufficiently dense.
High-density images may be uneven in density.
Outlines in high density images may blur.
Copyright CANON INC. 2017 |
