<License/Other>
1713-04H
You can register licenses and configure the settings related to the software and system options available for the machine.
<Register License>
  <Management Settings>  <License/Other>
Enter the license key for a system option that can be used on the machine. Installing System Options
<Print System Information>
  <Management Settings>  <License/Other>  <MEAP Settings>
You can print information for MEAP applications and certain system applications as a report. Printing a List of Settings
<Use TLS>
Select whether to use TLS communication when a MEAP application is used by accessing the machine via a Web browser.
<Confirm TLS Certificate Using MEAP Application>
Select whether to verify TLS server certificates and their common names (CN) when TLS communication is used for a MEAP application.
<Remote UI>
Select whether to use the Remote UI to operate the machine and change settings.
<Delete Message Board Contents>
Select to delete messages from the administrator that are displayed on the control panel.
<Remote Operation Settings>
Select whether to enable the Remote Operation function. This function enables you to specify settings and process jobs from a computer by displaying the screen of the touch panel display on the computer screen.
<Use ACCESS MANAGEMENT SYSTEM>
Select whether to use ACCESS MANAGEMENT SYSTEM. Using ACCESS MANAGEMENT SYSTEM
<Register/Update Software>
You can install system options/MEAP applications in the machine. Installing System Options
<Start Setup Guide>
You can follow the wizard instructions to configure the machine's initial settings. Setting up Using the Setup Guide
<Allow Use of Print Function from Mobile>
If this setting is set to <On>, you can perform operations from a mobile device for documents stored in <Print> on the Main Menu.
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
