You can use the logs to check or analyze how the machine is being used. A variety of information about each operation is recorded in the logs, such as the operation date/time, user name, operation type, function type, and operation result. For more information on the types of logs, see Specifications. Administrator privileges are required in order to manage the logs.
Start the Remote UI [Settings/Registration] [Device Management] [Export/Clear Audit Log] [Export Audit Logs] [Export] Follow the on-screen instructions to save the file
If you want to automatically delete all logs after they are exported, select the check box for [Delete logs from device after export] before clicking [Export]. If you then click [Cancel], exporting is canceled and the logs are deleted, even if they were not finished being exported as files.
