Setting Binding Margins
1713-0AF
You can make binding margins for stapling or punching holes. You can set binding margins on the front side and back side of pages individually.
When the margin is set, images are shifted by the margin width and copied. An original whose image extends all the way to the edges of the sheet may be partially cut off on the copy.
1
Place the original. Placing Originals
2
Press <Copy> on the Main Menu. <Main Menu> Screen
3
Press <Options> on the Copy Basic Features screen. Copy Basic Features Screen
4
Press <Gutter>.
5
Select the margin position.
If <Gutter> is set with <N on 1> (Copying Multiple Originals onto One Sheet (N on 1)), the margin specified for the front side is applied to both sides. The margin specified for the back side is not applied.
6
Enter the margin width.
Press <Front Side> or <Back Side> and enter each margin width.
If you enter a number smaller than 0, the margin is set on the opposite side of the position specified in step 4. Use this if you want to narrow the margin width when copying an original that already has margins.
If you press <±>, the value switches between <-> and <+>.
7
Press <OK>  <Close>.
8
Press .
Copying starts.
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
