<Adjust Image Quality>
1713-03X
This section describes how to adjust image quality for copying and printing.
<Auto Adjust Gradation>
  <Adjustment/Maintenance>  <Adjust Image Quality>
If the brightness of the printing is significantly different from the original document, this correction adjusts the printing so that it more closely matches the original document. Adjusting Gradation
<Correct Density>
If the density of the printing is significantly different from the original document, this correction adjusts the printing so that it more closely matches the original document. Adjusting Density
<Correct Shading>
If the image areas of the printing have uneven density, this correction adjusts the printing so that the density is even. Correcting Uneven Density
<Auto Correct Color Mismatch>
If the colors of printing run or blur, color mismatch (color misregistration) may have occurred. This correction adjusts the printing so that color mismatch does not occur. Correcting Color Mismatch
<Full Color Printing Vividness Settings>
This setting enables you to make colors more saturated when performing color printing. Making Colors More Vivid
<Fine Adjust Zoom>
If the size of the image copied is significantly different from the original document, fine adjustment is performed so that the printing more closely matches the size of the original document. Adjusting Image Size
<Dither Pattern Settings>
Set the dither pattern to produce printed images with smoother gradation and edges. Setting the Dither Pattern
<Adjust Toner Volume Used for Color Printing>
By adjusting the amount of toner used when color printing, you may be able to reduce problems such as streaks and irregularities. Reducing Toner Used When Color Printing
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
