You can set whether to use the machine as a USB device.
If this is set to <Off>, print and scan jobs from a computer connected via USB cable cannot be performed.
<Use MEAP Driver for USB Input Device>
<Preferences> <External Interface> <USB Settings>
You can set whether to use the MEAP driver for USB input device connections.
Depending on the type of MEAP application that uses device such as a keyboard or card reader, you may need to set this to <On>. To check whether you need to set this to <On>, see the manual for the MEAP application you are using, or contact your local authorized Canon dealer.
<Use MEAP Driver for USB Storage Device>
You can set whether to use the MEAP driver for USB external storage.
Depending on the type of MEAP application that uses USB external memory device, you may need to set this to <On>. To check whether you need to set this to <On>, see the manual for the MEAP application you are using, or contact your local authorized Canon dealer.
<Use USB Storage Device>
You can set whether to allow the use of USB external storage devices.
