User's Guide | |
1
Press <Home Folder>
2
Specify the home folder and press <OK>.
![]() ![]() Select the protocol to use when sending scanned documents to the Personal folder.
![]() Enter the host name or IP address of the computer where you want to create the home folder.
![]() Enter the folder path for the home folder. For example, enter "users\public\share" for a home folder created inside a subfolder named "share" in the "Public" folder on the C: drive (path: "C:\users\public\share").
![]() You may not be able to specify the path if there are too many folder levels.
3
Select the authentication information to use, and press <OK>.
To use a separate user name and password for the Personal folder, press <Use Authentication Info. of Each User> to add a check mark. Remove the check mark to use the same user name and password entered at login. If a check mark is added to this item, a user name and password must be registered for each user.
1
Press <Use Login Server>.
2
Registering a Personal folder and authentication information for each userThe Personal folder and user name/password can be set for each user by pressing <Scan and Send>
