User's Guide | |
1
Press <DNS Server Address Settings>.
2
Carry out the necessary settings.
According to your environment, enter an IP address of the DNS server.
![]() ![]() Press <Primary DNS Server>, and enter an IPv4 address of the DNS server.
If there is a secondary DNS server, enter its IP address. If you don't set a secondary DNS server, enter "0.0.0.0".
![]() Press <Primary DNS Server>, and enter an IPv6 address of the DNS server. You cannot enter addresses that begin with "ff" (multicast address), addresses that consist of only "0," or local link addresses.
If there is a secondary DNS server, enter its IP address. You cannot enter addresses that begin with "ff" (multicast address), addresses that consist of only "0," or local link addresses. This column can be left blank.
3
Press <OK>.
1
Press <DNS Host/Domain Name Settings>.
2
![]() ![]() Press <Host Name>, and enter the host name of the machine to register on the DNS server using alphanumeric characters.
Press <Domain Name>, and enter the domain name which the machine belongs to using alphanumeric characters (Example: "example.com").
![]() To set the host name and domain name to be the same as IPv4, press <On> in <Use Same Host Name/Domain Name as IPv4>. To set to be different from those of IPv4, press <Off>.
To set the host name to be different from IPv4, press <Host Name> and enter the host name of the machine to register on the DNS server using alphanumeric characters.
To set the domain name to be different from IPv4, press <Domain Name> and enter the domain name that the machine belongs to using alphanumeric characters. (Example: "example.com").
![]() If you set <Use DHCPv6> to <On> for the stateful address settings (Setting an IPv6 Address), the manually configured domain name is overwritten. If you set <Use Same Host Name/Domain Name as IPv4> to <On>, the domain name that is retrieved from DHCPv6 server is used.
3
Press <OK>.
1
Press <DNS Dynamic Update Settings>.
2
![]() ![]() To automatically update the information when correspondence between the host name and the IP address is changed in an environment such as DHCP, press <On> in <DNS Dynamic Update>.
Turn <On> the address you want to register as a DNS server in <Register Stateless Address>/<Register Manual Address>/<Register Stateful Address>. Please note that automatic update cannot be carried out if all are set to <Off>.
3
Press <OK>.
1
Press <mDNS Settings>.
2
![]() ![]() To enable the DNS function in an environment without a DNS server, press <On>.
Press <mDNS Name>, and enter an mDNS name of your choice using alphanumeric characters.
To set the same settings as IPv4 for the mDNS name, press <On> for <Use Same mDNS Name as IPv4>. To use different settings, press <mDNS Name> and enter an mDNS name of your choice using alphanumeric characters.
![]() If you set <Use IPv4 mDNS> to <On>, the machine will not completely enter the Sleep mode.
If you set <Use IPv6 mDNS> to <On>, the machine will not completely enter the Sleep mode.
3
Press <OK>.
