Cannot send documents to a server using the scan and send function.
Are the server settings such as the password correct?
If the login password, etc. of the server (computer) has been changed, make sure to also change the settings registered in the address book or one-touch buttons.
Are the settings for the SMTP server or DNS server correct?
If no e-mail can be sent, set the SMTP server and DNS server correctly. Also, if the port number for SMTP Send or receiving with POP are different from the default, specify the correct port numbers in <Specify Port Number for SMTP TX/POP RX>.
