Setting Up
Setting up the usage environment is required before using each function of the machine. First, confirm the processes to complete "setting up" prior to actual setup. Preparations Required Before Use
Administrators and General Users
To manage the machine, it is recommended to construct a system in which someone is appointed as an administrator and general users operate the machine under the management of an administrator. Administrators decide the rules for using the machine and operate important setups such as networks and security. Administrators set the access for each user when necessary.
TIPS
Carrying out the initial setup of the machine (Setup Guide)
You can easily set up to start using the machine, such as setting the date and time and networks, by following the the on-screen instructions. Setting up Using the Setup Guide
1713-000
