User's Guide | |
You can manually send fax documents after checking that the destination is ready to receive fax transmissions.
Manual Sending is not available in the following casesAny of the following scan settings are specified: <2-Sided Original>/<Different Size Originals>/<Erase Frame>/<Job Build>/<Delayed Send>/<Finished Stamp>
<Limit Functions> is set to <Off> for any function when the machine is in the Department ID mode. Configuring the Department ID Management Settings
To specify the scanning size of originalsThe scanning size of originals placed in the feeder is automatically set. To specify the size yourself, use the platen glass.
