Main Unit
1713-0SR
Name
Canon imageRUNNER ADVANCE C3530i / C3525i
Type
Desktop
Color Supported
Full Color
Resolution for Reading
600 x 600 dpi
Resolution for Writing
2,400 dpi x 600 dpi (enhanced by smoothing technology)
Number of Tones
256
Acceptable Originals
Up to 11 3/4" x 17" (297 x 431.8 mm): Sheet, book, three dimensional objects
Copy Size/Copy Paper
Paper Sizes
Max: 12 5/8" x 18" (320 x 457.2 mm)*1
Min: 3 7/8" x 5 1/2" (98.4 x 139.7 mm)
Margin
Top: 3/16" (4.0 mm)
Left and Right: 1/8" (2.5 mm)
Bottom: 1/8" (2.5 mm)
Paper Weight
Paper Drawer: 16 lb bond to 60 lb cover (52 to 220 g/m²)
Multi-Purpose Tray: 16 lb bond to 80 lb cover (52 to 300 g/m²)
Paper Type
Warm-Up Time
After Powering ON
30 seconds*2
Returning from the Sleep mode
10 seconds*3
First Copy Time
Full Color: 8.2 seconds
Black-and-White: 5.9 seconds
Copy Speed*4
30 sheets/minute
imageRUNNER ADVANCE C3525i
25 sheets/minute
Magnification
Regular Paper Size
Same Ratio: Direct±0.5%
Enlargement: 121%, 129%, 200%, 400%
Reduction: 78%, 73%, 64%, 50%, 25%
Zoom
25% to 400% (in 1% increments)
Paper Feeding System/Capacity
Paper Drawer
550 sheets (21 lb bond (80 g/m²))/640 sheets (17 lb bond (64 g/m²)) x 1
Multi-Purpose Tray
100 sheets (21 lb bond (80 g/m²))/120 sheets (17 lb bond (64 g/m²)) x 1
Multiple Copies
999 sheets
Power Source
120 - 127 V AC, 60 Hz, 7.5 A
Power Consumption
Maximum Power Consumption
1.5 kW or less
When the machine is in the Sleep mode
0.8 W or less (When <Sleep Mode Energy Use> is set to <Low>)
When the main power switch is turned OFF
When <Quick Startup Settings for Main Power> is set to <Off>: 0.1 kW or less
When <Quick Startup Settings for Main Power> is set to <On>: 0.45 kW or less
* The values may differ depending on the environmental conditions or use conditions.
Dimensions
(W x D x H)
22 1/4" x 29 1/4" x 35 1/2" (565 x 742 x 900 mm)
Weight
(Toner bottle included)
Approximately 178.6 lb (81 kg)
Maximum Occupancy Space
(W x D)
38 1/2" x 44 1/4" (978 x 1,123 mm)
Memory Capacity
RAM
Main CPU: 2 GB
Image processing CPU: 1 GB
HDD
250 GB
Inner Tray Capacity
250 sheets (21 lb bond (80 g/m²))*5
*1 Including multi purpose tray
*2 If <Quick Startup Settings for Main Power> is set to "On", it takes 7 seconds until the key operation on the touch panel display is available after turning on the main power of the machine. Depending on the situations, the machine does not startup quickly.
*3 Activation time may vary, depending on the environment and conditions under which the machine is being used.
*4 The speed on LTR size plain paper on one-side printing is measured during continuous copying. The speed vary depending on the output resolution, and the paper type and size. The speed on smaller paper sizes may be slower. Plus, the machine may experience downtime or decrease the speed in the middle of a continuous copy run to adjust the temperature inside the machine or maintain the optimal print quality.
*5 When LTR or smaller size paper is used.
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
