It is convenient to register a frequently used destination in a one-touch button. This enables you to quickly specify a destination with the simple press of a button. In addition to registering a fax number or e-mail address in a one-touch button, you can also register a file server folder location (IP address and path) to use when storing scanned data.
Destinations registered in one-touch buttons can be combined into a group and registered as a single destination. For details, see Registering a Group in a One-Touch Button.
To change or delete the information of destinations registered in one-touch buttons, see Editing the Registered Destinations in One-Touch Buttons.
TIPS
If the LDAP server has already been registered in the machine (Registering the LDAP Server), you can search for destinations and register them in one-touch buttons. Press <Dest./Fwd. Settings> <Register One-Touch> select the one-touch button you want to register press <Register/Edit> <LDAP Server> and search for destinations using <Search by Conditions> or <Search by Name>. After confirming the settings of the destination, press <One-Touch Name> enter the one-touch name to be displayed press <OK>.
When the user name and password are correct but the search result is empty, check the time setting both on the LDAP server and the machine. If the time setting between the LDAP server and the machine differs by five minutes or more, a search cannot be performed.
Unlike the Address Book, you cannot select more than one destination at a time to register.
The destination information you can acquire through searching only includes names and e-mail addresses.
Registering an address from the send historyYou can register a destination in a one-touch button from sent job logs in the <Status Monitor/Cancel> screen. This saves the labor of manually entering a fax number and other destination information, and contributes to prevention of wrong transmission due to use of destination information registered incorrectly. When you specify an address in sent job logs and press <Register Destination> <One-Touch>, a screen for registering various items of destination information in a one-touch button.
Checking Status and Log for Sent and Received Documents Checking Status and Log for Scanned Documents |
