Adjusting the Color
1713-09W
Adjust the density of yellow, magenta, cyan, and black separately.
1
Place the original. Placing Originals
2
Press <Copy> on the Main Menu. <Main Menu> Screen
3
Press <Options> on the Copy Basic Features screen. Copy Basic Features Screen
4
Press <Color Balance>.
5
Press <-> or <+> for each color to adjust the color balance.
6
Press <Fine Adjust Density>, and perform other adjustments as necessary.
Select a color and adjust its density level by its density area using the <-> or <+> button. When adjustment is complete, press <OK>.
7
Press <OK> <Close>.
8
Press .
Copying starts.
TIPS
You can register up to four settings after adjustment. After adjusting the color, press <Recall/Register> select a button from <C1> to <C4> press <Register> <Yes> <OK>.
To recall registered settings, press <Recall/Register>, select a button, and press <OK>.
You can change the button names of <C1> to <C4>. Select the button to change, press <Rename>, and enter a new name.
To delete registered settings, select the button press <Delete> <Yes>.
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
