Checking the Remaining Amount of Consumables
1713-059
When you press , the Status Monitor/Cancel screen is displayed, allowing you to check the toner level, the space remaining in the waste toner container, and the remaining amount of staples.
TIPS
You can check the remaining amount of consumables from the Remote UI. Checking the Machine Status
Checking the Toner Level
It is recommended that you check the remaining amount of staples before, especially beginning an operation to make a large number of booklets to determine whether you need to prepare a new staple case.
Press   <Consumables/Others>  check the toner level.
Checking the Space Remaining in the Waste Toner Container
It is recommended that you check the space remaining in the waste toner container before performing a large job to determine whether or not to prepare a new waste toner container.
Press  <Consumables/Others>  checking the space remaining in the waste toner container.
Checking the Remaining Amount of Staples
Press  <Consumables/Others>  check the remaining amount of staples.
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
