Address Book Items
1713-0RX
This section describes each column of the Address Book. Refer to this section when editing CSV files.
Header
Header Name
Required
Notes
# Canon AddressBook CSV version: 0x0001
Yes
Fixed value
# CharSet: UTF-8
Yes
Fixed value
# dn: fixed
Yes
(Required for One-touch button Address Book)
Indicates that the destination name is handled as a one-touch button. Entry is only required when the import destination is a one-touch button Address Book.
Added when exporting from a one-touch button Address Book, so there is no need to add this item again when importing.
# SubAddressBookName: Address Book name
Yes
Enter the Address Book name after the colon (:), with a space in between. If the Address Book is unnamed, leave the space after the colon (:) blank.
# DB Version: 0x010a
Yes
Fixed value
# Crypto Version: 2
No
Leave this section blank if you are creating a new Address Book CSV file.
# Crypto Attribute: pwd
No
The presence a header relating to "Crypt" in a header indicates that the password attribute is encrypted. However, when entering this information into a newly-created CSV file, or when editing the pwd attribute of an exported CSV file, encryption cannot be performed in a manner that allows the machine to correctly decode. In such cases, delete the corresponding portion from the header.
Body
Attribute Name
Description
Required
Notes
objectclass
Object class (destination type)
Yes
Indicates the type of destination. The required attribute varies according to this value. Enter one of the following.
For e-mail: email
For G3 fax: g3fax
For IP fax: ipfax
For fax: ifax
For file server (SMB, FTP, WebDAV): remotefilesystem
For group: groupfids
cn
Destination name
No
Enter in UTF-8 character code. Otherwise, the destination name will be left blank.
cnread
Phonetic alphabet
No
Displayed as "phonetic" if the display language is set to "Japanese".
cnshort
One-touch button name
No
Enter in UTF-8 character code. Otherwise, the one-touch button name will be left blank.
subdbid
Address Book number
No
Specify which Address Book to import to in the Remote UI. Not required when writing to a CSV file.
mailaddress
E-mail address
Yes
(Required for certain destination types)
This attribute is required for e-mail and I-fax destinations.
dialdata
Fax number
Yes
This attribute is required for fax destinations. However, it is not required if the destination is an IP fax using a URI.
uri
The URI used with an IP fax
Yes
Only usable for IP fax destinations. This attribute is required if you do not specify a fax number for an IP fax.
For an IP fax destination using a URI, you must also specify the "URI flag" (see below).
url
File server destination host name
Yes
This attribute is required for file server destinations. You can only use letters and symbols.
path
File path for file server destination
No
protocol
Protocol
Yes
This attribute is required for file server destinations. Enter one of the following.
For SMB: smb
For FTP: ftp
For WebDAV: addonprotocol0225
username
User name used when logging in to a file server destination
Yes
This attribute is required for FTP file server destinations. The user ID is required to log in to a file sending destination, and therefore is also required for file sending destinations using authentication, such as SMB and WebDAV.
pwd
Password used when logging in to a file server destination
No
This attribute is required for file sending destinations using authentication.
member
A member of a group destination
Yes
This attribute is required for group destinations.
indxid
A serial number allocated to a destination
Yes
This attribute is required if the import destination is a one-touch button Address Book. This number becomes the one-touch button number. In other cases, enter a number from 201 to 1,800.
enablepartial
Setting for dividing data when sending an e-mail
No
Enter either "on" or "off".
sub
Subaddress of a file server destination
No
faxprotocol
Fax protocol
No
g3
ecm
ecm
Indicates the use of ECM.
No
txstartspeed
Starting transmission speed for faxing
No
2400
4800
7200
9600
14400
33600
commode
Fax communication mode
Setting regarding international sending
No
For PSTN domestic line: domestic
For PSTN international line 1: international1
For PSTN international line 2: international2
For PSTN international line 3: international3
lineselect
Selected fax line
No
Enter one of the following. Otherwise, "auto" is used.
For lines 1 to 4: line1, line2, line3, or line4
For automatic line specification: auto
uricommode
IP fax communication mode
Yes
This is the chosen communication mode for IP faxes. This attribute is required if you use IP faxing, and are sending to a fax destination.
For G3: ip_g3
For intranet: ip_lsv
For a VoIP gateway: ip_gw
uriflag
The flag for a URI used with an IP fax
Yes
This attribute is required if the destination is an IP fax, and you use a URI instead of a fax number. Enter either "TRUE" or "FALSE". If you use a URI, enter "TRUE".
pwdinputflag
Setting for requesting password input per transmission
No
ifaxmode
I-Fax mode (simple/full)
No
Enter either "simple" or "full".
transsvcstr1
I-fax relay service text string 1
No
Enter total of up to 40 alphanumeric characters and symbols.
transsvcstr2
I-fax relay service text string 2
No
Enter total of up to 16 alphanumeric characters and symbols.
ifaxdirectmode
I-fax direct sending
No
documenttype
I-fax document type
No
To send in color: cl
To send in black and white: bw
bwpapersize
Paper size allowable when sending an I-fax
No
bwcompressiontype
Compression format used when sending an I-fax
No
bwpixeltype
Color space allowable when sending an I-fax
No
bwbitsperpixel
Bit count allowable when sending an I-fax
No
bwresolution
Resolution allowable when sending an I-fax
No
clpapersize
Paper size allowable when sending a color I-fax
No
clcompressiontype
Compression format used when sending a color I-fax
No
Fixed as "jpeg".
clpixeltype
Color space allowable when sending a color I-fax
No
Fixed as "rgb".
clbitsperpixel
Bit count allowable when sending a color I-fax
No
Fixed as "8".
clresolution
Resolution allowable when sending a color I-fax
No
accesscode
Access code
No
Enter up to seven numbers.
uuid
A UUID for identifying a destination
No
This item is not necessary when creating a new CSV file.
cnreadlang
Phonetic alphabet character code
No
Displayed as "phonetic" if the display language is set to "Japanese". Enter the language code to use. For Japanese (SJIS), enter "ja".
enablesfp
Unused
No
This item is unused, and therefore does not need to be entered.
memberobjectuuid
Used for Personal Address List/User Group Address List
No
loginusername
No
logindomainname
No
usergroupname
No
personalid
No
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
