Paper Jams in the Feeder
1713-06S
Check the paper jam location on the screen, and follow the procedure below to remove the original.
1
Remove the originals in the original supply tray.
2
Check whether an original is jammed in the feeder cover.
Pull the lever to open the feeder cover.
If an original is jammed, gently pull it out in the direction of the arrow.
If you cannot remove the jammed original, proceed to the next step without forcibly removing it.
3
Check whether an original is jammed in the original output tray.
Turn the green knob counterclockwise.
4
After removing all jammed originals, close the feeder cover.
5
Lift up the feeder, and check whether there is a jammed original.
Lift up the feeder, and check the position indicated by .
6
Return the feeder to its original position.
Continue following the instructions on the screen to proceed with the interrupted operation or continue clearing paper jams.
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
