Staple Jam Has Occurred in the Booklet Finisher
1713-074
Clearing Staple Jams in the Staple Unit
Open the front cover of the finisher.
Pull out the staple cartridge.
Hold the green knob on the staple cartridge and pull the cartridge straight out.
Remove the jammed staple(s) from the staple cartridge.
Lift up the knob on the staple cartridge.
Remove all jammed staples and exposed staples.
Return the knob on the staple cartridge to its original position.
Hold the green knob on the staple cartridge and push in the cartridge as far as it will go.
Close the front cover of the finisher.
Dry stapling may be performed automatically for staple repositioning.
Clearing Staple Jams in the Saddle Stitcher Unit
Pull out the saddle stitcher unit.
Remove the (two) staple cartridges while pulling down the lever towards you.
Lower the knob on the staple cartridge.
Install the (two) staple cases in the saddle stitch unit.
Gently return the saddle stitcher unit to its original position.
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
