Saving Documents in Memory Media1713-0J0
Follow the procedures below to convert scanned documents into a file format commonly supported by a computer to save in memory media. This method is convenient when you need to move files to a computer not connected to a network.
Set the original.
Placing Originals
Press <Scan and Store> on the Main Menu.
<Main Menu> Screen
Press <Memory Media>.
Select the desired memory media.
Display the save location and press <Scan>.
Specify the scan settings as necessary.
Press
Originals are scanned and saved as files.
To cancel scanning, press <Cancel> or
<Yes>.
When <Press the [Start] key to scan the next original.> is displayed
Place the next original to scan and press
. After scanning all of the originals, press <Start Storing> to save the file.
To check the result of saving, press
<Store>
<Job Log>. If <NG> is displayed, the file is not saved successfully. Try the operation again.
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-00 2017-02 Copyright CANON INC. 2017
