User's Guide | |
Confirm before handlingBefore starting the operation to clear paper jams, confirm that the covers and paper drawers of the machine and optional equipment are closed.
Open the upper cover of the fixing assembly.
If paper is jammed, gently pull it out in the direction of the arrow.
![]() ![]() If you cannot remove the paper via the top side of the fixing assembly, gently pull it out via the bottom side of the assembly.
Return the upper cover of the fixing assembly back to position.
Lift the duplex unit.
If paper is jammed in the upper area of the duplexing unit, gently pull it out in the direction of the arrow.
Return the duplex unit back into position.
If paper is jammed in the lower area of the duplexing unit, gently pull it out in the direction of the arrow.
