Setting Up Connection by Selecting a Wireless Router
1713-00F
You can search the wireless routers available for connection and select one from the display of the machine. For the network key, enter a WEP key or PSK. Before selecting a wireless router, check and write down the required setup information, including the SSID and network key. Checking the SSID and Network Key
Security settings
If the wireless connection is set up by selecting a wireless router, the WEP authentication method is set to <Open System> or the WPA/WPA2 encryption method is set to <Auto> (AES-CCMP or TKIP). If you want to select <Shared Key> for WEP authentication or <AES-CCMP> for WPA/WPA2 encryption, set up the connection in <Enter Manually>. Setting Up a Connection by Specifying Detailed Settings
1
Press .
2
Press <Preferences>  <Network>  <Wireless LAN>  <Wireless LAN Settings>  <Other (Set Manually)>.
3
Press <Select Access Point>.
The machine starts searching for available wireless routers.
4
Select a wireless router, and connect to it.
If the security setting of your wireless LAN router is WEP or WPA/WPA2-PSK
1
Select the wireless LAN router to use, and press <OK>.
2
Press <WEP Key> or <PSK>, and enter the network key.
3
Press <OK>.
When the configuration is complete, the screen <Connected.> will be displayed.
If the security setting of your wireless LAN router is other than WEP or WPA/WPA2-PSK
1
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
