<Copy>
1713-043
This section describes how to specify the copy settings.
<Register/Edit Favorite Settings>
  <Function Settings>  <Copy>
You can register a combination of settings frequently used when copying to a single button. You can also assign a name to the button. Registering a Combination of Frequently Used Functions
<Change Default Settings>
You can change the settings registered as default for the <Copy> function.
<Register Options Shortcuts>
You can register modes in the shortcut keys displayed on the Copy screen. This feature is useful when you want to register frequently used functions.Registering a Combination of Frequently Used Functions
<Auto Collate>
If this setting is set to <On>, the machine can automatically switch between <Collate (Page Order)> and <Offset> for the finishing mode when originals are placed in the feeder. This is useful when making multiple sets of copies, because you do not need to remember to select the Finishing mode.
<Auto Recognize Original Orientation>
If you set this setting to <On>, even if the orientation of the original you placed differs from the orientation set in the feeder, the image is rotated 90 degrees and copied according to the orientation of the original.
<Select Color Settings for Copy>
You can restrict the use of the color mode in <Select Color> when copying.
<Speed Priority for Copying from Feeder>
You can give a priority to speed over accuracy when copying from feeder.
<Job Separator Between Groups>
When copying two copies or more with <Group (Same Pages)> in <Finishing>, you can insert sheets between each page group. If you select <On>, select a paper source.
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
