Specifying Authentication Method for SMTP Server
0R9W-1XR
You can specify the authentication method for accessing an SMTP server.
The administrator selects the authentication information used when accessing the SMTP server.
(See "Setting Administrators.")
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Set Authentication Method].
Press [Info. Used for SMTP Server Authentication].
4.
Select information used for SMTP server authentication.
Details of each item are shown below:
[Device Settings]:
Uses the information for SMTP server authentication set in the machine. (See "Common Communication Settings for E-Mail/I-Fax.") Further settings are not required for every user.
[Regist. Info. for Each User]:
Uses the authentication information registered by each user of an SMTP server. Further settings are required for each user.
5.
Press [OK].
Log in to the machine.
Press [Main Menu] → [Scan and Send] →
Press [Register/Edit Info. for Each User].
You can register user information from  on the [Scan and Send] Basic Features screen and the [Fax/I-Fax Inbox] Send screen.
4.
Press [SMTP Server Authentication Information].
5.
Enter the user name and password used for SMTP Server authentication → press [OK].
