Category Top
Overview of the Authentication System
Setting Administrators
How User Authentication Works
System Requirements
Login Methods
Setting User Authentication (for the Administrator)
Managing User Information
Using the Touch Panel Display
Using the Remote UI
Setting the User Authentication Function Environment
Using the Remote UI
Changing the User Authentication System
Users Changing Their Own Passwords
User Setting Information Management (User Setting Information Management Service)
Accessing the Advanced Box of Another Machine
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Authentication Password Security Settings
Displaying a Warning When Logging In with the Default Password
Allowing the Default Password to Be Used When Logging In from the Remote UI
Setting Password Restrictions
Setting the Lockout Function
Authentication Settings for Device Information Distribution
ACCESS MANAGEMENT SYSTEM
Available Settings for Administrator Table (Touch Panel Display)
Available Settings for Administrator Table (Remote UI)
Other Login Services
Logging In with DepartmentID Authentication (When Department ID Management Is Enabled)
Setting Department ID Management (for the System Manager)
Specifying the System Manager Settings
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
Using the Remote UI
Top » Authentication » Login Methods
Login Methods
0R9W-1WC
This section describes the login methods. Users can log in using the control panel of the machine or from the Remote UI.
The default user name for the Administrator of Local Device Authentication is 'Administrator' and the default password is '7654321' (case sensitive).
When using Local Device Authentication, make sure to edit the user information of the Administrator immediately after starting to use it, in order to increase security. (See "Managing User Information.")
If you are logging in as the Administrator for Local Device Authentication and the default user name and password are still being used, a screen prompting you to change the password may be displayed when you click [Log In], depending on the settings. It is recommended that you change the password to increase security.
If you are logging in as the Administrator for Local Device Authentication from the Remote UI and the default user name and password are still being used, you may not be able to log in, depending on the settings. In this case, log in from the touch panel display, and change the user name and password.
If [Auto Reset Time] is set, users are automatically logged out when a certain amount of time elapses. (See "Auto Reset Time.")
The procedure may differ if you are using another login service.
For instructions on selecting and setting a login service, see "Login Service Selection."
For information on registering users for Local Device Authentication, see "Managing User Information."
For information on the user names in Server Authentication + Local Device Authentication, ask the Administrator.
Logging In to the Machine Using the Control Panel
Users must log in to use the functions that require authentication.
Press [Log In].
A login screen may be displayed when starting to operate the machine and after the machine is turned ON, depending on the settings of the authentication system.
If using the Administrator authentication mode or Standard authentication mode:
If using the Administrator authentication mode, only users with administrator privileges can log in.
If using the Guest authentication mode:
Users can also log in as guest users by pressing [Guest Log In].
If the Access Management System is enabled, you can use the "Guest User" role, which has limited functions, to log in to the machine without entering a user name and password. (See "ACCESS MANAGEMENT SYSTEM Administrator Guide.")
Press [User Name].
To use Server Authentication + Local Device Authentication, a Windows server in which Active Directory is installed or an LDAP server is required. (See "How User Authentication Works.")
To log in with Active Directory authentication, it is necessary to synchronize the time of the computer in which Active Directory is running and the time of the machine. If there is a difference of more than 30 minutes in the time of the computer and the time of the machine, an error occurs when you log in. For information on setting the date and time of the machine, see "Current Date and Time."
You can also specify the number of user's logs displayed on the touch panel display when logging in.
If you are using Active Directory authentication, you can use only alphanumeric characters and the symbols - _ ` { } ~ ! # $ % & ' ( ) @ ^ for user names. You can log in only if you use valid characters. (Case sensitive.)
If you are using Local Device Authentication, use the following characters. (Case sensitive.)
User name: Alphanumeric characters, symbols (with the exception of \ / : * ? | < > [ ] ; , = + @ ") and spaces not exceeding a total 32 characters
Password: Alphanumeric characters not exceeding a total 32 characters (no symbols)
4.
Enter the user name → press [Next].
5.
Enter the password → press [OK].
6.
Select the Login destination from the <Login Destination> drop-down list.
If you are using Server Authentication + Local Device Authentication, select the login destination from the drop-down list. For information on selecting the login destination, see "How User Authentication Works."
If Local Device Authentication is set as the user authentication system, only [This device] is displayed in the <Login Destination> drop-down list.
The names of the domains or the names of the server of the LDAP server which allow user authentication are displayed in the <Login Destination> drop-down list.
Regardless of the items displayed in the <Login Destination> drop-down list, the domain which the machine belongs to appears at the top of the list, and [This device] appears at the bottom of the list.
If seven or more items are displayed in the <Login Destination> drop-down list, [ Alphabetical], , and are displayed in the <Login Destination> drop-down list.
If you press [Alphabetical], the items displayed in the <Login Destination> drop-down list are displayed in reverse alphabetical order, and the key changes to [ Alphabetical].
If you press [ Alphabetical], the items displayed in the <Login Destination> drop-down list are displayed in alphabetical order, and the key changes to [ Alphabetical].
Press to scroll down the list.
Press to scroll up the list.
7.
Press [Log In].
You can also press (Log In/Out) to log in.
If the user name or password that you entered is incorrect, a message appears prompting you to verify your user name and password. Repeat this procedure from step 3.
8.
After you finish using the machine, press [Log Out] on bottom right of the screen.
You can also press (Log In/Out) to log out.
If you log out, you must log in again to use functions that require authentication.
When you finish operating the machine, log out to maintain security.
The items displayed in the Remote UI differ according to the privileges assigned to the user that is logged in.
Start your Web browser → enter the following URL in the address bar.
http://<IP address or host name of the machine>/
Enter/select each item → click [Log In].
Users can also log in as guest users by pressing [Log In (General User)].
If the ACCESS MANAGEMENT SYSTEM is enabled, you can use the "Guest User" role, which has limited functions, to log in to the machine without entering a user name and password. (See "ACCESS MANAGEMENT SYSTEM Administrator Guide.")
If logging in using Local Device Authentication:
Enter the user name and password → select [This device] in [Login Destination:].
If logging in using Server Authentication + Local Device Authentication:
Enter the user name and password → select the domain name or the LDAP server name in [Login Destination:].
Make sure you log out before closing the Web browser when you finished your operations. If you close the Web browser without logging out, the Remote UI cannot be used for a while, even if you try to log in again with the same account.
Do not use the browser's [Back] button. If you use [Back] to change pages, the Remote UI may not operate correctly.
The default user authentication system is 'Local Device Authentication'. For information on setting the user authentication system, see "Setting the User Authentication Function Environment."
