Setting User Authentication (for the Administrator)
0R9W-1WE
You can set the authentication system according to your environment, such as registering users and assigning roles.
When performing user management, management groups called "roles" are assigned to users to limit the functions that the users can use.
For details on the roles available by default, see "ACCESS MANAGEMENT SYSTEM Administrator Guide."
If the ACCESS MANAGEMENT SYSTEM is enabled, you can customize roles to limit the functions for each user in more detail.
(See "ACCESS MANAGEMENT SYSTEM.")
The settings for the current authentication information can be checked from [Authentication Service Information] in [Management Settings] (Settings/Registration).
The Administrator is set as the Local Device Authentication administrator for the machine by default. Therefore, the administrator must log in by entering the user name and password for the Administrator. The default user name is 'Administrator' and the default password is '7654321' (case sensitive).
