Category Top
Overview of the Authentication System
Setting Administrators
How User Authentication Works
System Requirements
Login Methods
Setting User Authentication (for the Administrator)
Managing User Information
Using the Touch Panel Display
Using the Remote UI
Setting the User Authentication Function Environment
Using the Remote UI
Changing the User Authentication System
Users Changing Their Own Passwords
User Setting Information Management (User Setting Information Management Service)
Accessing the Advanced Box of Another Machine
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Authentication Password Security Settings
Displaying a Warning When Logging In with the Default Password
Allowing the Default Password to Be Used When Logging In from the Remote UI
Setting Password Restrictions
Setting the Lockout Function
Authentication Settings for Device Information Distribution
ACCESS MANAGEMENT SYSTEM
Available Settings for Administrator Table (Touch Panel Display)
Available Settings for Administrator Table (Remote UI)
Other Login Services
Logging In with DepartmentID Authentication (When Department ID Management Is Enabled)
Setting Department ID Management (for the System Manager)
Specifying the System Manager Settings
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
Using the Remote UI
Top » Authentication » Other Login Services » Department ID Management » Using the Touch Panel Display » Checking/Printing/Clearing Page Totals
0R9W-1X5
You can check, print, and clear the page total of printed surfaces output by each department.
Press [Management Settings] → [User Management] → [Department ID Management].
Display the page totals screen.
When the Copy Card Reader-F1 is not attached:
When the Copy Card Reader-F1 is attached:
Press [On] → [Page Totals].
Press [Page Totals].
4.
Check/print/clear the counter information.
The page totals that belong to print jobs without a Department ID (left blank) include:
prints from computers that do not correspond with a registered Department ID
counter reports
received fax/I-fax documents
The page totals that belong to scan jobs without a Department ID (left blank) are the number of pages that have been scanned from computers that do not correspond with a registered Department ID. These scanned pages from computers are referred to as network scans with unknown IDs.
If [Large2 Count Management] is pressed, one sheet of large paper (11" x 17") is counted as two sheets in the print total.
To check/print the page totals:
To clear the page totals:
Press [Print List] → select the type for Page Count List → press [Start Printing].
Press or to display the desired Department ID → view the desired page totals. By holding down  or , you can scroll quickly and continuously backward or forward through the available Department ID pages. When the desired page is displayed, release the keys. Continuous scrolling is useful when a large number of Department IDs are registered.
To cancel printing, press [Cancel].
To close the screen that is displayed while the machine is printing the Page Count List, press [Close].
Lists can be printed only if 11" x 17", LGL, LTR, or LTRR paper (plain, recycled, thin, or color) is loaded in a paper drawer that is set to 'On' in [Other] in [Paper Drawer Auto Selection On/Off] in [Function Settings] (Settings/Registration). However, if [Consider Paper Type] for [Copy] is set to 'On' in [Paper Drawer Auto Selection On/Off], you cannot print from a paper drawer with color paper specified. (See "Enabling Paper Drawer Auto Selection.")
Press [Clear All Totals].
Press [Yes].
To clear all page totals at a time by department, press or to display the desired department → select the department → press [Clear].
5.
Press [OK] → [OK].
If you are using a control card, you can also check the page totals by pressing [Status Monitor/Cancel] → [Consumables] → [Check Page Count].
