Category Top
Overview of the Authentication System
Setting Administrators
How User Authentication Works
System Requirements
Login Methods
Setting User Authentication (for the Administrator)
Managing User Information
Using the Touch Panel Display
Using the Remote UI
Setting the User Authentication Function Environment
Using the Remote UI
Changing the User Authentication System
Users Changing Their Own Passwords
User Setting Information Management (User Setting Information Management Service)
Accessing the Advanced Box of Another Machine
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Authentication Password Security Settings
Displaying a Warning When Logging In with the Default Password
Allowing the Default Password to Be Used When Logging In from the Remote UI
Setting Password Restrictions
Setting the Lockout Function
Authentication Settings for Device Information Distribution
ACCESS MANAGEMENT SYSTEM
Available Settings for Administrator Table (Touch Panel Display)
Available Settings for Administrator Table (Remote UI)
Other Login Services
Logging In with DepartmentID Authentication (When Department ID Management Is Enabled)
Setting Department ID Management (for the System Manager)
Specifying the System Manager Settings
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
Using the Remote UI
Top » Authentication » Setting the User Authentication Function Environment » Using the Touch Panel Display
0R9W-1WR
Some of the Preferences settings can be specified from the touch panel display.
Login Screen Display Settings
You can set the timing for displaying the login screen and the functions to restrict.
You can select to display the login screen either when a user starts to operate the machine or when a user selects a function.
[Display When Oper. Started]:
Users start operations after logging in from the login screen.
[Display When Func. Slctd.]:
The login screen is displayed when users press a function button such as [Copy]. You can also limit the users that can perform color copying/printing and only allow administrators to change the settings in Settings/Registration. (See "Setting Administrators.")
Functions and Settings/Registration screens without login limitations can be freely used.
Limiting the Usage of Functions
You can set whether to limit printing from printer drivers that do not use the AMS Printer Driver Add-in or remote scanning.
For information on the AMS Printer Driver Add-in, see the instruction manuals for the ACCESS MANAGEMENT SYSTEM. (See "ACCESS MANAGEMENT SYSTEM Administrator Guide")
Setting the Timing for Displaying the Login Screen
Press [Management Settings] → [User Management] → [Authentication Management] → [Login Screen Display Settings].
Set the timing for displaying the login screen and the functions to restrict.
Displaying the Login Screen When Starting to Operate the Machine:
To perform authentication when a user starts to operate the machine, press [Display When Oper. Started].
Displaying the Login Screen When Selecting a Function:
To perform authentication when a user uses a function, press [Display When Func. Slctd.].
Set the functions that require authentication.
[Functions]:
Select the functions that require authentication.
[Color Copy/Print]:
Displays a message prompting the user to log in when performing color copying/color printing. Logging in is required to perform color printing.
 Select [Restrict All Operations] or [Restrict Certain Oper.].
[Restrict All Operations]:
No items in Settings/Registration cannot be set unless the user logs in.
[Restrict Certain Oper.]:
Of the items in Settings/Registration, only those that require administrator privileges are limited by authentication.
Press [OK].
Setting the Functions to Limit
Press [Management Settings] → [User Management] → [Authentication Management] → [Functions to Restrict].
Specify each setting → press [OK].
[Print from Drivers without AMS Printer Driver Add-in]:
Restricts printing from computers in which the AMS Printer Driver Add-in is not installed and computers with an unknown user logged on. This setting can be specified when the ACCESS MANAGEMENT SYSTEM is enabled. (See "ACCESS MANAGEMENT SYSTEM Administrator Guide")
[Remote Scan]:
Restricts the function for scanning data to a computer by using the machine as a scanner. When [Restrict] is set, the machine does not become online even if [Scanner] is selected on the Main Menu.
Settings specified from the control panel become effective after the machine is restarted, after the procedure. If <Perform Apply Setting Changes from Settings/Regist.> is displayed on the bottom of the touch panel display, you can press [Apply Set. Chng.] in (Settings/Registration) to restart the machine. For information on restarting the machine using the main power switch, see "Main Power and Energy Saver Key."
