Category Top
Overview of the Authentication System
Setting Administrators
How User Authentication Works
System Requirements
Login Methods
Setting User Authentication (for the Administrator)
Managing User Information
Using the Touch Panel Display
Using the Remote UI
Setting the User Authentication Function Environment
Using the Remote UI
Changing the User Authentication System
Users Changing Their Own Passwords
User Setting Information Management (User Setting Information Management Service)
Accessing the Advanced Box of Another Machine
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Authentication Password Security Settings
Displaying a Warning When Logging In with the Default Password
Allowing the Default Password to Be Used When Logging In from the Remote UI
Setting Password Restrictions
Setting the Lockout Function
Authentication Settings for Device Information Distribution
ACCESS MANAGEMENT SYSTEM
Available Settings for Administrator Table (Touch Panel Display)
Available Settings for Administrator Table (Remote UI)
Other Login Services
Logging In with DepartmentID Authentication (When Department ID Management Is Enabled)
Setting Department ID Management (for the System Manager)
Specifying the System Manager Settings
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
Using the Remote UI
Top » Authentication » Other Login Services » Department ID Management
0R9W-1X2
You can register a Department ID and PIN (up to seven digits) for each department, and manage the machine by limiting its use to only those who enter the correct Department ID and PIN. This is called Department ID Management. Department IDs and PINs for up to 1,000 departments can be registered. Use Department ID Management to keep track of the copy, scan, and print totals for each department.
This section describes the following settings:
Registering the Department ID and PIN
Setting the copy, scan, and print page limits
Setting the functions to use Department ID Management for (The Copy function is automatically restricted whenever Department ID Management is set.)
Checking the copy, scan, and print page totals
If you are using the Server Authentication + Local Device Authentication of User Authentication and set [Department ID Management] to 'On', you may not be able to log on. In this case, change the login service to DepartmentID Authentication → set [Department ID Management] to 'Off'. For information on setting the login service, see "Setting Application Authentication Information."
If the Copy Card Reader-F1 is attached, and DepartmentID Authentication is set as the login service, Department ID Management is automatically activated. (See "Copy Card Reader-F1.")
If User Authentication is set as the login service, Department ID Management is performed on the Department ID that shares the same user name as the one registered for User Authentication.
The information registered for Local Device Authentication of User Authentication, and the user information and password registered for Department ID Management must match. If the Department ID and PIN have been changed due to distribution of device information, make sure to change the Local Device Authentication settings accordingly. For instructions on registering user information for Local Device Authentication, see "Managing User Information."
If User Authentication is set as the login service, the Limit Functions mode is not available.
If Department ID Management is activated through the Copy Card Reader-F1, the Department IDs assigned to the cards are used. Therefore, you cannot register Department IDs.
