Allowing the Default Password to Be Used When Logging In from the Remote UI
0R9W-24L
You can set the machine to allow the default password to be used when logging in from the Remote UI.
Allowing the default password should only be used as a temporary measure when you have forgotten the password, etc., as it is not recommended for security reasons.
Using the Touch Panel Display
Press
(Settings/Registration).
Press [Management Settings] → [Security Settings] → [Authentication/Password Settings] → [Password Settings].
Press [Allow Use of Default Password for Remote Access] → [On].
If you select [Off], you will become unable to log in using the default password, regardless of the setting in [Display Warning When Default Password Is in Use].
4.
Press [OK].
Click [Settings/Registration]→[Security Settings]→[Authentication/Password Settings].
Press [Edit...] for <Password Settings>.
Select [Allow Use of Default Password for Remote Access] → click [OK].
If you do not allow the default password to be used, you will become unable to log in using the default password, regardless of the setting in [Display Warning When Default Password Is in Use].
