Category Top
Overview of the Authentication System
Setting Administrators
How User Authentication Works
System Requirements
Login Methods
Setting User Authentication (for the Administrator)
Managing User Information
Using the Touch Panel Display
Using the Remote UI
Setting the User Authentication Function Environment
Using the Remote UI
Changing the User Authentication System
Users Changing Their Own Passwords
User Setting Information Management (User Setting Information Management Service)
Accessing the Advanced Box of Another Machine
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Authentication Password Security Settings
Displaying a Warning When Logging In with the Default Password
Allowing the Default Password to Be Used When Logging In from the Remote UI
Setting Password Restrictions
Setting the Lockout Function
Authentication Settings for Device Information Distribution
ACCESS MANAGEMENT SYSTEM
Available Settings for Administrator Table (Touch Panel Display)
Available Settings for Administrator Table (Remote UI)
Other Login Services
Logging In with DepartmentID Authentication (When Department ID Management Is Enabled)
Setting Department ID Management (for the System Manager)
Specifying the System Manager Settings
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
Using the Remote UI
Top » Authentication » Other Login Services » Department ID Management » Using the Remote UI
Using the Remote UI
0R9W-1X8
Follow the procedure below to specify Department ID Management settings from the Remote UI.
Click [Settings/Registration] → [User Management] → [Department ID Management].
The list of Department IDs registered in the machine appears in groups of 100. If you want to display another group, select a group other than [1-100] from the drop-down list → click [Display].
Department ID Management is set automatically if the Copy Card Reader-F1 is attached to the machine. If the Copy Card Reader-F1 is attached, [Register New Department] and [Delete Department] do not appear.
To set the method for managing Department IDs, click [Settings...] → specify the desired settings → click [OK].
Item
Setting Content
[Enable Department ID Management]:
If you select this check box, Department ID Management is enabled. When Department ID Management is enabled, the user must enter the Department ID to be able to use functions, such as the Copy and Send functions. (This enables you to keep track of the total number of prints by department and set impression limits.) In addition, when Department ID Management is enabled, the user must enter the Department ID and PIN to be able to execute jobs and perform operations on the Memory RX Inbox or Confidential Fax Inboxes.
If the Copy Card Reader-F1 is attached, this check box does not appear.
[Limit Functions]:
This setting enables you to set Department ID Management for [Scan and Store], [Access Stored Files], [Fax/I-Fax Inbox], [Scan and Send], [Fax], [Scanner], and [Web Access] functions. If User Authentication is being used, the Limit Functions mode is not available.
[Store/Access Files, Fax/I-Fax Inbox]:
Select this check box to set Department ID Management for [Scan and Store], [Access Stored Files], and [Fax/I-Fax Inbox] functions.
[Send/Fax]:
Select this check box to set Department ID Management for [Scan and Send] and [Fax] functions.
[Other]:
Select this check box to set Department ID Management for [Scanner] and [Web Access] functions.
[Allow Printer Jobs with Unknown IDs]:
Select this check box to enable printing for computers that use printer drivers that do not support Department ID Management. If you do not select this check box, only computers with printer drivers that support Department ID Management can print.
[Allow Remote Scan Jobs with Unknown IDs]:
Select this check box to enable remote scanning for computers that use printer drivers that do not support Department ID Management. If you do not select this check box, only computers with printer drivers that support Department ID Management can perform remote scanning.
[Allow Black & White Copy/Print Jobs]:
Select this check box to accept all black-and-white copy jobs and print jobs regardless of Department ID Management.
[Allow Black & White Printer Jobs]:
Select this check box to accept all black-and-white print jobs regardless of Department ID Management.
[Count Each Page as 2 (Large Size Only)]
Select to count one large sheet (11" x 17") as two sheets in the print total.
[Clear All Counts]:
Click this button to reset the counter to zero for all departments.
For more information on the Limit Functions, see "Limiting Functions."
To register a department, click [Register New Department] → specify the desired settings → click [OK].
Item
Setting Content
[Department ID]:
Enter a number (seven digits maximum).
[PIN]:
[Confirm]:
Enter the PIN again. If the number you enter here is different from the number entered for <PIN>, an error dialog box appears.
[Page Limit]:
Enter the maximum number of prints the department is allowed to make.
If the Copy Card Reader-F1 is attached, you cannot register a new department.
[Total Prints] is the sum of copy and print jobs.
4.
To delete a department, click the department that you want to delete → click [Delete Department].
5.
Click [OK].
6.
To change the PIN and page limit setting, click the desired Department ID → change the necessary fields on the <Edit Department> screen → click [OK].
To clear the print total for the department, click [Clear Count]. Click [OK] when the confirmation dialog box appears.
