For information on the types of administrators, see "Setting Administrators."
Settings/Registration
Administrator/System Manager
NetworkAdmin
DeviceAdmin
[Paper Settings]
[Paper Type Management Settings]
[Display Settings]
[Default Screen after Startup/Restoration]
[Display Fax Function]
[Store Location Display Settings]
[ID/User Name Display On/Off]
[Display Remaining Toner Error Message]
[IP Address Display Settings]
[Timer/Energy Settings]
[Date/Time Settings]
[Time Format]
[Quick Startup Settings for Main Power]
[Restrict Auto Reset Time]
[Network]
[Confirm Network Connection Set. Changes]
[TCP/IP Settings]
[IPv4 Settings]
[IPv6 Settings]
[DNS Settings]
[Computer Name/Workgroup Name Settings]
[WINS Settings]
[LPD Print Settings]
[RAW Print Settings]
[SNTP Settings]
[FTP Print Settings]
[WSD Settings]
[Use FTP PASV Mode]
[IPP Print Settings]
[Multicast Discovery Settings]
[Use HTTP]
[SSL Settings]
[Proxy Settings]
[Confirm Dept. ID PIN]
[IPSec Settings]
[AppleTalk Settings]
[SNMP Settings]
[Format Host Resources MIB to RFC2790]
[Dedicated Port Settings]
[Use Spool Function]
[Waiting Time for Connection at Startup]
[Ethernet Driver Settings]
[IEEE 802.1X Settings]
[Firewall Settings]
[IPv4 Address Filter]
[IPv6 Address Filter]
[MAC Address Filter]
[IP Address Block Log]
[External Interface]
[USB Settings]
NetworkAdmin
DeviceAdmin
[Adjust Image Quality]
[Dither Pattern Settings]
[Adjust Toner Volume Used for Color Printing]
NetworkAdmin
DeviceAdmin
[Common]
[Paper Output Settings]
[Use Optional Output Tray]
[Print Settings]
[Copy Set Numbering Option Settings]
[Secure Watermark/Document Scan Lock]*
[Scan Settings]
[Auto Online]
[Auto Offline]
[Generate File]
[Rights Management Server Settings]
[Document Scan Lock Operational Settings]
[Set Authentication Method]
[Copy]
[Select Color Settings for Copy]
[Printer]
[Restrict Printer Jobs]
[PDL Selection (Plug and Play)]
[Send]
[Common Settings]
[TX Report]
[Confirm SSL Certificate for WebDAV TX]
[Limit New Destination]
[Always Add Device Signature to Send]
[Limit E-Mail to Send to Myself]
[Restrict File TX to Personal Folder]
[Personal Folder Specification Method]
[Restrict Resending from Log]
[E-Mail/I-Fax Settings]
[Communication Settings]
[Confirm SSL Certificate for SMTP TX]
[Confirm SSL Certificate for POP RX]
[Maximum Data Size for Sending]
[Default Subject]
[Specify Authentication User Dest. to Reply]
[Set Authentication User Destination to Sender]
[Allow Unregistered Users to Send E-Mail]
[Full Mode TX Timeout]
[Print MDN/DSN upon Receipt]
[Use Send via Server]
[Allow MDN Not via Server]
[Restrict TX Destination Domain]
[Auto Complete for Entering E-Mail Addresses]
[Fax Settings]
[Use Auth. User Name as Sender Name]
[Fax TX Report]
[Set Line]
[TX Start Speed]
[PIN Code Access]
[Confirm Entered Fax Number]
[Allow Fax Driver TX]
[Confirm Before Sending When Fax Dest. Incl.]
[Restrict Seq. Broadcast When Fax Dest. Incl.]
[Remote Fax TX Settings]
[Receive/Forward]
[Common Settings]
[Interrupt and Print RX Jobs]
[Handle Files with Forwarding Errors]
[Forwarding Settings]
[Set Fax/I-Fax Inbox]
[Memory RX Inbox PIN]
[Use Fax Memory Lock]
[Use I-Fax Memory Lock]
[Memory Lock Start Time]
[Memory Lock End Time]
[Divided Data RX Timeout]
[Always Send Notice for RX Errors]
[Fax Settings]
[RX Start Speed]
[RX Password]
[Store/Access Files]
[Common Settings]
[Limit Box PIN to 7 Digits/Restrict Access]
[Mail Box Settings]
[Settings for All Mail Boxes]
[Box Security Settings]
[Network Settings]
[Protocol for External Reference]
[Confirm SSL Certificate for Network Access]
[Memory Media Settings]
[Secure Print]
[Simple Authentication Settings]
[Only Allow Encrypted Print Jobs]
NetworkAdmin
DeviceAdmin
[Address Book PIN]
[Manage Address Book Access Numbers]
[Include Pswd. When Exporting Address Book]
[Register LDAP Server]
[Auto Search When Using LDAP Server]
[Change Default LDAP Search Conditions]
[Register/Edit LDAP Search Conditions]
[Acquire Remote Address Book]
NetworkAdmin
DeviceAdmin
[User Management]
[Authentication Management]
[Register/Edit Authentication User]
[User Authentication]
[Login Screen Display Settings]
[Functions to Restrict]
[System Manager Information Settings]
[Department ID Management]
[Device Management]
[Device Information Settings]
[Device Information Distribution Settings]
[Limited Functions Mode]
[Certificate Settings]
[Display Job Status Before Authentication]
[Restrict Access to Other User Jobs]
[Display Job Log]
[Save Audit Log]
[Store Key Operation Log]
[License/Other]
[Register License]
[MEAP Settings]
[Remote UI]
[Delete Message Board Contents]
[Remote Operation Settings]
[Use ACCESS MANAGEMENT SYSTEM]*
[Register/Update Software]
[Start Setup Guide]
[Data Management]
[Import/Export]
[Delete Existing Data Settings]
[Initialize All Data/Settings]
[TPM Settings]
[Security Settings]
[Authentication/Password Settings]
[Authentication Function Settings]
[Password Settings]
