Category Top
Overview of the Authentication System
Setting Administrators
How User Authentication Works
System Requirements
Login Methods
Setting User Authentication (for the Administrator)
Managing User Information
Using the Touch Panel Display
Using the Remote UI
Setting the User Authentication Function Environment
Using the Remote UI
Changing the User Authentication System
Users Changing Their Own Passwords
User Setting Information Management (User Setting Information Management Service)
Accessing the Advanced Box of Another Machine
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Authentication Password Security Settings
Displaying a Warning When Logging In with the Default Password
Allowing the Default Password to Be Used When Logging In from the Remote UI
Setting Password Restrictions
Setting the Lockout Function
Authentication Settings for Device Information Distribution
ACCESS MANAGEMENT SYSTEM
Available Settings for Administrator Table (Touch Panel Display)
Available Settings for Administrator Table (Remote UI)
Other Login Services
Logging In with DepartmentID Authentication (When Department ID Management Is Enabled)
Setting Department ID Management (for the System Manager)
Specifying the System Manager Settings
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
Using the Remote UI
Top » Authentication » Setting User Authentication (for the Administrator) » Managing User Information
0R9W-1WF
You can register and edit user data for authentication using Local Device Authentication. You can also import and export user data in bulk.
Only users with Administrator privileges can edit user information.
It is recommended that you export the registered/edited user data to make a backup copy.
User information can only be imported and exported from the Remote UI.
User Information Settings
Item
Setting Content
Setting Conditions
Default Setting
[User Name:]
Set user name when logging in.
Must be from 1 to 32 characters. You cannot include spaces or the following symbols (\ / : * ? l < > [ ] ; , = + @ ")
Case sensitive.
You cannot register a user name that has already been registered.
Administrator
[Password:]
Set password when logging in.
You can leave this blank or enter up to 32 characters.
Case sensitive.
7654321
[Confirm:]
Enter the password you entered for [Password:].
Case sensitive.
7654321
[Department ID:]
To use authentication in conjunction with Department ID Management, set the Department ID.
Select a registered Department ID.
For information on registering Department IDs, see "Specifying Department ID Management."
0000000
[PIN:]
Set PIN corresponding to Department ID.
You can leave this blank or enter up to 7 digits. (This can be omitted if Department ID Management is set to 'Off').
If the number you enter does not contain enough digits, zeros are added to the front of the number.
0000000
[Confirm:]
Enter the PIN you entered for [PIN:].
0000000
[Displayed As:]
Set the user display name (for example, user's full name, user's department name, etc.)
Administrator
[E-Mail Address:]
Set the user's e-mail address.
You can leave this blank or enter up to 256 characters and symbols.
The format of e-mail addresses is not checked.
Blank
[Select Role to Set:]
Set the user role (privileges).
You can select a role that has been set.
For details on each role, see "ACCESS MANAGEMENT SYSTEM Administrator Guide."
Administrator
[Card ID:]*
If the control card reader is attached, enter the card ID.
You can leave this blank or enter up to 8 characters.
You cannot enter only zeros, such as <0000>.
Blank
*Indicates items that appear only when the control card reader is attached.
If [Department ID Management] is set to 'On', the registered information for Local Device Authentication and the registered user data and PIN in the machine's Department ID Management have to match. If the Department ID and PIN have been changed due to the delivery of device information, make sure to change the Local Device Authentication settings accordingly.
If you are using Server Authentication + Local Device Authentication and set [Department ID Management] to 'On', you may not be able to log on. In this case, change the login service to DepartmentID Authentication → set [Department ID Management] to 'Off'. For instructions on setting a login service, see "Setting Application Authentication Information."
The information registered for Local Device Authentication, and the user information and password registered for Department ID Management must match.
If no e-mail address is registered, you need to set [Allow Unregistered Users to Send E-Mail] in [Function Settings] (Settings/Registration) to 'Off' to send e-mails/I-faxes.
The login user name and e-mail address are displayed on the sender field ("from") on the e-mail recipient's machine. However, if an e-mail address that exceeds 194 characters is entered, only the first 193 characters of the address are displayed.
The login user's e-mail address is displayed on the sender field on the I-fax recipient's machine.
Multiple users can share the same Department ID.
Multiple users with Administrator privileges can be registered.
Enter the same string for [Password]/[PIN] and [Confirm]. If you enter a different string for [Password]/[PIN] and [Confirm], a message prompting you to re-enter the passwords/PIN appears.
