Category Top
Overview of the Authentication System
Setting Administrators
How User Authentication Works
System Requirements
Login Methods
Setting User Authentication (for the Administrator)
Managing User Information
Using the Touch Panel Display
Using the Remote UI
Setting the User Authentication Function Environment
Using the Remote UI
Changing the User Authentication System
Users Changing Their Own Passwords
User Setting Information Management (User Setting Information Management Service)
Accessing the Advanced Box of Another Machine
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Authentication Password Security Settings
Displaying a Warning When Logging In with the Default Password
Allowing the Default Password to Be Used When Logging In from the Remote UI
Setting Password Restrictions
Setting the Lockout Function
Authentication Settings for Device Information Distribution
ACCESS MANAGEMENT SYSTEM
Available Settings for Administrator Table (Touch Panel Display)
Available Settings for Administrator Table (Remote UI)
Other Login Services
Logging In with DepartmentID Authentication (When Department ID Management Is Enabled)
Setting Department ID Management (for the System Manager)
Specifying the System Manager Settings
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
Using the Remote UI
Top » Authentication » Authentication Method Settings for Sending Operations
0R9W-1XC
You can specify what type of authentication method you use for accessing personal folders or external servers, and which user name and password you use as authentication information.
The available authentication information for this function varies, depending on the type of servers and protocols. For example, you can use the authentication information registered for each user or server, or information that login service specified.
For details, see the following:
Personal Folder (See "Specifying Personal Folders.")
LDAP Server (See "Specifying Authentication Method for LDAP Server.")
Rights Management Server (See "Specifying Authentication Method for Rights Management Server.")
SMTP Server (See "Specifying Authentication Method for SMTP Server.")
File Server (See "Specifying Authentication Method for File Server.")
Scenes that require entering authentication information to use sending function are as follows.
Scenes Required Authentication Information
The Server to Browse for
User Name and Password
Registering an address obtained via an LDAP server to the address book
LDAP Server
Searching the destination via an LDAP server when sending a scanned data as an attached file in an E-mail message
LDAP Server
Scanning the document and generating PDF files that have viewing and other privileges managed by the security policy
Sending a scanned data as an attached file in an E-mail message
SMTP Server
Sending a scanned data to a File server
File Server
SMB
WebDAV
FTP
Browsing a file in an Advanced Box of another machine
