Category Top
Overview of the Authentication System
Setting Administrators
How User Authentication Works
System Requirements
Login Methods
Setting User Authentication (for the Administrator)
Managing User Information
Using the Touch Panel Display
Using the Remote UI
Setting the User Authentication Function Environment
Using the Remote UI
Changing the User Authentication System
Users Changing Their Own Passwords
User Setting Information Management (User Setting Information Management Service)
Accessing the Advanced Box of Another Machine
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Authentication Password Security Settings
Displaying a Warning When Logging In with the Default Password
Allowing the Default Password to Be Used When Logging In from the Remote UI
Setting Password Restrictions
Setting the Lockout Function
Authentication Settings for Device Information Distribution
ACCESS MANAGEMENT SYSTEM
Available Settings for Administrator Table (Touch Panel Display)
Available Settings for Administrator Table (Remote UI)
Other Login Services
Logging In with DepartmentID Authentication (When Department ID Management Is Enabled)
Setting Department ID Management (for the System Manager)
Specifying the System Manager Settings
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
Using the Remote UI
Top » Authentication » Authentication Password Security Settings » Setting the Lockout Function
0R9W-1Y0
You can set a lockout function that temporarily prevents logging in for a user that fails user authentication. The lockout function enables increased security.
Item
Setting Content
[Enable Lockout]
Enables the lockout settings.
[Lockout Threshold]
Enables you to set the number of times that a user must fail user authentication before they are temporarily stopped from logging in. If a user fails the user authentication more than the set lockout threshold within three minutes, the login service is stopped. For example, if you set the lockout threshold to five times, the lockout function is enabled and the user is prevented from logging in for the specified period of time when a user fails user authentication five times in three minutes.
[Lockout Period]
Enables you to set the lockout period. When setting this from the Remote UI, enter the lockout time using single-byte characters.
Press [Management Settings] → [Security Settings] → [Authentication/Password Settings] → [Authentication Function Settings].
Press [Lockout Settings].
4.
Specify each setting.
Press [On] for <Enable Lockout>.
Press [Lockout Threshold] → press [-] or [+] to specify the number of times.
You can also use the numeric keys to enter values.
Press [Lockout Period] → press [-] or [+] to specify the time.
5.
Press [OK].
Using the Remote UI
Click [Settings/Registration] → [Security Settings]→[Authentication/Password Settings].
Press [Edit...] for <Authentication Function Settings>.
Select [Enable Lockout] → specify each setting → click [OK].
