Category Top
Overview of the Authentication System
Setting Administrators
How User Authentication Works
System Requirements
Login Methods
Setting User Authentication (for the Administrator)
Managing User Information
Using the Touch Panel Display
Using the Remote UI
Setting the User Authentication Function Environment
Using the Remote UI
Changing the User Authentication System
Users Changing Their Own Passwords
User Setting Information Management (User Setting Information Management Service)
Accessing the Advanced Box of Another Machine
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Authentication Password Security Settings
Displaying a Warning When Logging In with the Default Password
Allowing the Default Password to Be Used When Logging In from the Remote UI
Setting Password Restrictions
Setting the Lockout Function
Authentication Settings for Device Information Distribution
ACCESS MANAGEMENT SYSTEM
Available Settings for Administrator Table (Touch Panel Display)
Available Settings for Administrator Table (Remote UI)
Other Login Services
Logging In with DepartmentID Authentication (When Department ID Management Is Enabled)
Setting Department ID Management (for the System Manager)
Specifying the System Manager Settings
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
Using the Remote UI
Top » Authentication » Authentication Password Security Settings » Displaying a Warning When Logging In with the Default Password
0R9W-1XX
You can set the machine to display the screen for changing the password when the Administrator logs in to the machine using the default user name and password.
If you use the default password, security issues may arise. It is recommended that you change the password.
If the password has expired, the screen for changing the password appears, regardless of this setting.
Press [Management Settings] → [Security Settings] → [Authentication/Password Settings] → [Password Settings].
Press [Display Warning When Default Password Is in Use] → [On].
4.
Press [OK].
Using the Remote UI
Click [Settings/Registration] → [Security Settings] → [Authentication/Password Settings].
Press [Edit...] for <Password Settings>.
Select [Display Warning When Default Password Is in Use] → click [OK].
