Category Top
Overview of the Authentication System
Setting Administrators
How User Authentication Works
System Requirements
Login Methods
Setting User Authentication (for the Administrator)
Managing User Information
Using the Touch Panel Display
Using the Remote UI
Setting the User Authentication Function Environment
Using the Remote UI
Changing the User Authentication System
Users Changing Their Own Passwords
User Setting Information Management (User Setting Information Management Service)
Accessing the Advanced Box of Another Machine
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Authentication Password Security Settings
Displaying a Warning When Logging In with the Default Password
Allowing the Default Password to Be Used When Logging In from the Remote UI
Setting Password Restrictions
Setting the Lockout Function
Authentication Settings for Device Information Distribution
ACCESS MANAGEMENT SYSTEM
Available Settings for Administrator Table (Touch Panel Display)
Available Settings for Administrator Table (Remote UI)
Other Login Services
Logging In with DepartmentID Authentication (When Department ID Management Is Enabled)
Setting Department ID Management (for the System Manager)
Specifying the System Manager Settings
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
Using the Remote UI
Top » Authentication » Authentication Password Security Settings » Setting Password Restrictions
0R9W-1XY
You can set the number of characters, expiration period, and complexity of passwords. These settings prevent simple passwords from being registered to increase security.
Item of the Touch Panel Display
Item of the Remote UI
Setting Content
[Minimum Length Settings]
[Set Minimum Number of Characters for Password]
You can set the minimum number of characters required when registering a password to prevent the simplification of passwords.
When a password length is set, a user cannot be registered with a blank password.
[Validity Period Settings]
[Set Password Validity Period]
You can set a password expiration period to force users to periodically change their password, in order to prevent the simplification of passwords.
When setting this from the Remote UI, enter the password expiration period using single-byte characters.
[Prohibit Use of 3 or More Same Consec. Char.]
[Prohibit Use of 3 or More Identical Consecutive Characters]
You can restrict the characters that can be used for passwords to prevent the use of simple passwords.
[Use at Least 1 Uppercase Character]
[Force Use of at Least 1 Uppercase Character]
[Use at Least 1 Lowercase Character]
[Force Use of at Least 1 Lowercase Character]
[Use at Least 1 Digit]
[Force Use of at Least 1 Digit]
[Use at Least 1 Symbol]
[Force Use of at Least 1 Symbol]
Password restriction settings are valid for passwords that are registered/edited after the restrictions are set. When a password that is already registered exceeds the restrictions for these settings, a screen prompting to change the password is displayed when user authentication is performed.
Press [Management Settings] → [Security Settings] → [Authentication/Password Settings] → [Password Settings].
Select each setting.
4.
Specify the selected settings.
Press [On] → press [-] or [+] to specify the number of characters.
You can also use the numeric keys to enter values.
Press [On] → press [-] or [+] to specify the number of days that passwords are valid.
Press [On].
Press [On].
Press [On].
Press [On].
Press [On].
5.
Press [OK].
Using the Remote UI
Click [Settings/Registration] → [Security Settings]→[Authentication/Password Settings].
Press [Edit...] for <Password Settings>.
Enter the necessary data → click [OK].
