For information on the types of administrators, see "Setting Administrators."
Settings/Registration
Administrator/System Manager
NetworkAdmin
DeviceAdmin
[Restart Device]
[Apply Settings]
[Paper Settings]
Paper Settings
Paper Type Management Settings
[Timer/Energy Settings]
Date/Time Settings
Time Format
Quick Startup Settings for Main Power
Restrict Auto Reset Time
[Network Settings]
Output Report
TCP/IP Settings
IPv4 Settings
IPv6 Settings
WINS Settings
Computer Name/Workgroup Name Settings
LPD Print Settings
RAW Print Settings
SNTP Settings
WSD Settings
FTP PASV Mode Settings
IPP Print Settings
Multicast Discovery Settings
HTTP Settings
SSL Settings
Proxy Settings
Department ID PIN Confirmation Settings
IPSec Settings
AppleTalk Settings
SNMP Settings
Dedicated Port Settings
Spooler
Waiting Time for Connection at Startup
Ethernet Driver Settings
IEEE 802.1X Settings
Firewall Settings
IPv4 Address Filter
IPv6 Address Filter
MAC Address Filter
IP Address Block Log
[External Interface]
USB Settings
NetworkAdmin
DeviceAdmin
[Common Settings]
Paper Feed Settings
Paper Drawer Auto Selection/Paper Drawer Auto Selection Based on Color
Feed Method Switch
Suspended Job Timeout
Paper Output Settings
Output Tray Settings
Offset Jobs
Job Separator Between Jobs
Job Separator Between Copies
Print Settings
Print Priority
Text/Photo Priority When Recognized as Black & White by ACS
Output Report Default Settings
Register Characters for Page Number/Watermark
Copy Set Numbering Option Settings
Secure Watermark/Document Scan Lock Settings*1
Scan Settings
Feeder Jam Recovery Method
Scanner Noise Settings
LTRR/STMT Original Selection
Remote Scan Gamma Value
Generate File
Image Quality Level for Compact
OCR (Text Searchable) Settings
Trace & Smooth Settings
OOXML Settings
Word File Image Settings
Specify Minimum PDF Version
Format PDF to PDF/A
Optimize PDF for Web
256-bit AES Settings for Encrypted PDF
Rights Management Server Settings
Document Scan Lock Operational Settings
Set Authentication Method
[Copy]
Select Color Settings for Copy
[Printer]
Output Report
Custom Settings
UFR II
PCL
PS
Imaging
PDF
XPS
Restrict Printer Jobs
PDL Selection (Plug and Play)
Secure Print
[Send]
Output Report
Common Settings
TX Report/Communication Management Report*3
Network Settings - E-Mail/I-Fax Settings
Communications Settings - E-Mail/I-Fax Settings
Limit New Destination
Favorite Settings
Only Send E-Mail to Myself
Only Send File to Personal Folder
Limit Send Destination
TX Settings - Fax Settings
Register Sender Name (TTI)
Fax TX Report/Fax Activity Report*4
Set Line
Communications Settings-Fax Settings
Confirm Entered Fax Number
Allow Fax Driver TX
Remote Fax TX Settings
[Receive/Forward]
Output Report
Common Settings
Divided Data RX Timeout/Always Send Notice for RX Errors
Forwarding Settings
Memory Lock Settings
Fax Settings-RX Settings
Fax RX Report/Confidential Fax Inbox RX Report
RX Start Speed/RX Password
[Store/Access Files]
Settings for All Mail Boxes
Box Security Settings
Network Settings
Network Place Settings
Protocol for External Reference
SSL Certificate Confirmation Settings for Network Access
Memory Media Settings
NetworkAdmin
DeviceAdmin
[Address Lists (Output Report)]
[Address Book PIN]
[Manage Address Book Access Numbers]
[Address Book Export Settings]
[Register LDAP Server]
[Register/Edit LDAP Search]
[Acquire Remote Address Book]
NetworkAdmin
DeviceAdmin
[User Management]
Authentication Management
System Manager/Contact Person Information Settings
Department ID Management
[Device Management]
Device Information Settings
Certificate Settings
Key and Certificate Settings
CA Certificate Settings
Certificate Revocation List (CRL) Settings
Display Job Status Before Authentication
Restrict Access to Other User Jobs
Display Job Log
Save Audit Log
Export/Clear Audit Log
Network Authentication Log Settings
Key Operation Log Store Settings
Remote Shutdown
[License/Other]
Message Board/Support Link
Remote UI Settings
Remote Operation Settings
ACCESS MANAGEMENT SYSTEM Settings*2
MEAP Settings
Register/Update Software
[Data Management]
Delete Existing Data Settings
Import/Export All
Import/Export Individually
Back Up/Restore Settings
Security Settings
Authentication/Password Settings
